Yeah I spotted that this arvo.... Number plate was GTR.32X, very very loud, looks as though its got an extremely free flowing cat in it aswell lol, very wide rear tyres and super super clean....
Made my r33 gtst sound as quiet as an electric car when i was following it
The car is a machine!!!!!!!
Spoted Lanky71/Drew about an hour ago.. was walking to the shops and you drove past
Pitty it was such crap weather... you missed seeing a car accident at the corner there by like 15-20mins.
Took the gtr for a scenic drive around the city and beaches and stuff... we was bored. lol
spotted you again! at least this time you saw me for once haha :3some:
Yep true true, this time heading to darlingharbour for the night out, spotted sam916 in the city on george st at like 2am hempy/qantas was behind me... then a black r33 further down the rd.
Spotted a clean looking white R34 this morning at just before 8am i think, in Hornsby on George Street. (looked like URAS front bar??) :P
that was i sir.. on the way to work. full s1 uras kit. :P
spotted a maroon gts-t on some police tv show tonight on channel 7. the guy got defected and the presenter kept calling it a GTR.
ooh that would've grinded my gears,
you know what's a similar feeling...
I'm a guitarist, and it really sh$ts me when I see actors on the telly pretending to play while they lay over a recording and when the show takes it further, tries to make look "real" by making them move their hands up and down :P
It's NOT a FARKIN GTR and THEY'RE NOT really playing!!! :(:(:P
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
