spotted a Metalic Olive Green R33 at around 1pm driving west on showground road in tha hillz...
pretty decent paint job, saw it for a second but looks good
spotted a white r35 driving through telopea past the shops and school around 6'ish, then a black r32 at james ruse dr on ramp near parra, a silver r33 along carlingford rd followed by a white stagea and a burgundy r33... busy 45mins period lol
spotted a smashed R33.... near botany I think.. cant remember was on the way home from the airport
I think it was around Roselands or Beverley Hills when we saw that.
all on friday i spotted:
MADGTR turning near the Hills Lodge
Bayside Blue R34 GT-R KIW18U
Blue V35 with LMGT4's on Parramatta Road
Black R34 GTT with VIC plates near Auburn Maccas
Silver R33 GT-R on the M4
Silver R33 GTST RU3L8R
and a yellow R34 GTT near Croydon AIFANG
spotted R34LINER again on oldnorthern road castle hill, not sure on time but around 1.30-2.30ish, had a lady friend in passenger
On Sunday i spotted one of those 2-tone grey 33's P plater with a big green sticker on the back window that said 'FULLY SICK' LoL
Also a silver 33gtst came past my work today ass end was low as...sounded good.
ahh yes on the way to uni, didnt see you tho? were you in the line?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
