Spotted a white 33 GTR on the back of a trailer heading south on the M5 near brooks road saturday morning. A few porsche's went past on trailers as well so it must've been some kind of race meet.
Drove next to a silver Stagea in Dee Why yesterday arvo. Was undercover in a gold CRV though. It had a Nismo emblem on the side. Driver had a wrist brace and long hair.
Also a Red Stagea parked near Hornsby Hospital today sometime lol
Spotted this today along Mulgoa road heading towards Glenmore Park..
Hooning it in the wet and tried egging me on.. dont feel like dying today thanks :P
yeah seen him on that roundabout on york before the rta hooning it around, part of me says 'wanker' the other part smacks me on the back of the head saying I'd probably be thrashing it about if I had a car like that :ninja:
Spotted 20min ago, Black R35GTR JDM parked on York Street near QVB. Got to see it take off, and oh boy IT WAS THE FASTEST CAR I HAVE EVER SEEN TAKING OFF! You could literally feel the energy it was making and putting to the ground.
P.S Interesting that a R8 passed by just before the GTR took off :-)
Spotted a silver R34 parked on the street near Blacktown TAFE this afternoon around 2.15pm - had 4WD ride height and wheels that I wouldn't exactly say suited the car. :bunny::)
