Spotted a white 33 GTR on the back of a trailer heading south on the M5 near brooks road saturday morning. A few porsche's went past on trailers as well so it must've been some kind of race meet.
Drove next to a silver Stagea in Dee Why yesterday arvo. Was undercover in a gold CRV though. It had a Nismo emblem on the side. Driver had a wrist brace and long hair.
Also a Red Stagea parked near Hornsby Hospital today sometime lol
Spotted this today along Mulgoa road heading towards Glenmore Park..
Hooning it in the wet and tried egging me on.. dont feel like dying today thanks :P
yeah seen him on that roundabout on york before the rta hooning it around, part of me says 'wanker' the other part smacks me on the back of the head saying I'd probably be thrashing it about if I had a car like that :ninja:
Spotted 20min ago, Black R35GTR JDM parked on York Street near QVB. Got to see it take off, and oh boy IT WAS THE FASTEST CAR I HAVE EVER SEEN TAKING OFF! You could literally feel the energy it was making and putting to the ground.
P.S Interesting that a R8 passed by just before the GTR took off :-)
Spotted a silver R34 parked on the street near Blacktown TAFE this afternoon around 2.15pm - had 4WD ride height and wheels that I wouldn't exactly say suited the car. :bunny::)
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
