not as bad as the V35 SEDAN that had knock off GTR badges on both front quarters when I was filling up at the servo the other day, I was two rows over & you could still tell they were a cheapo ebay item too small & too red on the "R" it was like a neon red lulz
ahh was that v35 white? If so it was about 500kw and was built before nissan got around to doing the r35.....
i think I know which one you are talking about, it was at one of the sydney autosalons from memory didn't know the white one was a sedan though :D
no, this thing was a bog stock V35 silver sedan :P with knock off GTR badges on the two front quarters :P probably would've seen a dirty big one on the back had I not turned my head away in disgust
Spotted RJ (R 2 The J) and his 33 at thornleigh maccas, thanks for the bov should be on soon :D
and also a nice black 34 gtst very clean driving up pennant hills rd then at maccas you went into the drive through. JAY-XXX????
I was in the black stagea :)
white R33 s2 with standard yellow plates running up my arse on the M4 yesterday
then proceeded to cut through lanes of traffic to get ahead only for me to catch up anyway by the time you hit the servo/maccas after the blacktown exit
well done @ssbag, don't you know its DD's?
Man I spotted this car today too and yes it did have one on the back too lmao!
Saw these in Thailand, I think the Tuk Tuk was epic, it was all pimped out with R33 tail lights, exhaust, Massive sound system and assortment of led's and black lights....
did anyone notice the 2JZGTE engine and turbo on the boat???? DAmmit ive just zoomed into the pic now at home and i realise the potential that shack boat might have had, from a distance i didnt notice what engine it was :blush:
But still wtf? on a boat? I only saw one supra in Bangkok city...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
