Yeah show was good. Better than last years i think. What u think of it?
Was good to see the Skaife/Richards winning 32 in person too. Is sad that that car was the end of the turbo era in bathurst.
I too spotted this, there and then.
What you think of the show?
It was ok. Too expensive and too short. It was nice to see some WRX's on fire :)
CerealKiller - that tail light rewiring your talking about is standard on the aussie delivered GTRs the outer one is the indicator and the inner is the brake light with the lil square as the reverse light
IMO i think its oright i like it cause it gets rid of the reverse lights next to the number plate and there is a nice panel that finishes off the rear bar around the number plate mount instead of having big gaps up the top where the number plate lights are.
oh yea and i saw a nice sliver GTR in the back streets of gladesville yesterday i think its from BD4s
anyway its just my 2c
:D
you from around gladesville way??
lol 7 year old quote!
goes to show how old this thread is.
for what it is worth anf was based in west ryde until a few years ago when he opened dahtone racing in wetherill parkq
actually first page of this thread is funny.....
anf is still around sometimes
blitz, adrian and merli still are (admins), and here every now and then.
bman, abo bob, cereal killer, tosh, carlo, geoff, jeremey, dino, loz, franks....all lost in the sands of time
spoke to franks a few times after he headed to usa (driving a hummer of all things!)
dino and abo join the line of ex-nsw presidents who had enough with christian and dan. neil is next.
carlo still appears every now and then
kinks sold the 31, upgraded(?) to a 33, still around sometimes
tosh kinda disappeared from here but now has an s15, we talked a few weeks back when a common friend was in town from jp.
bman gave up on the 33 and turned up again years later with an s12 gazelle project - don't know if it ever made the road or track tho
loz finally got that gtr...but disappeared again too.
and BD4s shut down about 3 years ago when the partners split....and I have not seen cerealkiller on here in.....forever! at least since he crashed his gtir
I think you mean Dave (Cereal).
He now lives in Japan and being a bimmer driver now doesn't get on the forum much if at all.
anywho :) spotted black 34 gtt plate F1**7A at harbour bridge yesterday arvo after work im in the euro plates RAF***
and a black 33 at M5 tunnels same arvo I followed you until I overtook :(
so..i spotted this Mitsubishi Lancer GT-R with dual mirrors on each side, dual exhaust left and right, custom kits (mini bullbar at the rear) and custom vinyls. spotted at Blacktown Westfields. :D Oh and that black stripe to break the line is duct-tape.
oh wow :(
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
