got a flash from a gunmetal grey r32 gtr with plates GTR-32P around lunchtime at rocky point rd sans souci, had SAU stickers too
Hey mate sorry abot late reply that was me :blink: thanks for spoting. I saw your tough beast with nice intercooler very nice! :P
I was on my way to doctors and to get some cobwebs out of my pipe.
See ya around are you local?
Dave
Spotted about 10 or so R33's today! Probably more but lost count lol
Black R34 GTR at George street with black lmgt4's tonight! Looked insane!
Another black R34 GTT no idea what road but it was just outside the city!
Yellow R34 GT at lidcombe behind me at the lights :ermm:
And R32 GTR with plates GT32TR or something on the lines of that :down: at The Rocks tonight, had LED rear lights.
Finally Spotted, you must of been out of work early yesterday?
Well kind of. I had to compile some reports and then present them in a teleconference at 11pm to the US. Sarked deek.
Did you get new rims?
Ah ok, ive had them for a while they were on there at the last cruise.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
