Spotted a black R33 GTS-T, HUSTL3R, with a GTR badge on the side, on the Northern RD Penrith this morning.
Take that badge off!!! you are cheapening the legend!! or buy a real GTR!
ok who owns the R35 GTR that parks in my street every other day - its black with JJJ as the number plates!! please tell me because every morning that its there i almost crash my car driving past it as i check it out!!!
perhaps a http://www.abc.net.au/triplej/ JJJ employee?
Spotted aggroman parked at bernie mullane sporting complex last night. Well I think it is him, the only red N/A 34 with a P plate in wstrn syd that I have seen. I have also spotted you on samantha riley drive in kellyville x 11ty million.
Its no longer N/A and he doesn't have his p's anymore
Yeh wouldnt be him Jez he lives up the mountains and i don't think he comes out our way very often.
I see. Not him then. yellow + black generic plates xx-##-xx
probably not on here then i suppose.
My girlfriend spotted a white R33 Wednesday night at the bridge near Fairfield bowling. I didn't see because I was playing the drums on my tummy to the beat of a song LOL.
Anyways, she thought she saw SAU sticker on the side, just wondering who it is
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
