Oh, I've spotted a dark blue R34 GT or GTt a few times over the past few days rolling through and around Toongabbie.
Could be me, i work at Girraween
Mines a GTT though with BBS mesh style 18's
Are your wheels black, Jason? The 34 I've seen does have mesh-style wheels, but I can't remember what style, just the colour. Also, it's always been moving along, if it had been stopped somewhere I'd be better able to confirm what wheels they were.
Spotted an orange R32 with black bonnet around 4pm on Johnson Avenue in Seven Hills, I was going in the opposite direction in my Stagea and flashed my headlights at you. Looked nice!
Wasn't me :P
They are grey so might not have been me, i'll keep an eye out for your stagea.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
