Spotted over the past week:
Dark BNR32 with aftermarket wheels in Chatswood area
Dark R32 in Chatswood on Thursday evening skipping through town.
Forgot
Tonight, Silver BNR32 with 34 wheels in the Ryde area, and Gunmetal BNR32 with a wing on Cowpasture Rd.
2 days ago.. Black R34 GT parked at Macquarie Centre at North Ryde around 11am (AUD???)
Also R35 CENA parked at Macquarie University long time ago! lol.. about 3 months ago?.. niZmO_Man reminded me laugh.gif
Spotted so many nice Skylines in the car park at World Time Attack yesterday. I was surprised they didn't wave me off so I parked right under the grandstands. There were several 32 & 34 GTR's there in the same lot with me (plus Evo's and WRX's, etc).
he is a pretty shy kid. im not sure if he would know the name of the wheels because i know he bought them with the car but ill ask for you.
sorry but he didnt know the name of the wheels
also to keep this post on topic i saw a dark (blue or black) 4 door r34 with a gt-r badge in the front grille on parramatta rd on my way home from work yesterday.
Spotted BU57ED in woodcroft
Sounds mean as but what happened when u pulled away from the lights, didn't sound healthy :|
Hey Matty yeah its running real rich atm I did a fuel test last nite here in brissy .....I did 65 km and it used 13 litres of fuel witch works out to be. 200 ml of fuel per 1 km at crusing speed 110 kmh
Edited by high_hp
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
