All this spotting in Robertson and you didn't spot me last Saturday about 4.30pm? :(
My first time doing Mac Pass in the R34 :D
Really?
I would've just been getting to work.
Have fun?
That's my personal track.
is that the Cube I always see outside this big company that recently announced 1900 job losses?
yep that would be her. In a sensible piece of timing she has quit and taken a job with the Broadband network, starting monday
Really?
Have fun?
Yeah, too much traffic though!
I went that way home too on Sunday (even though I was up in Bulli at that point). Started off good, then came up to a small car who nicely moved into that little "slow vehicle" thingy for me, thought I had it all to myself and then came to about a million cars behind a bus farken.
Next time I'm not going home till LATE :D
I've only been there for 3 months, guess it might be time for this data analyst to pack his bags lol
Going opposite way
Didn't notice any subis but in that area I wouldn't be surprised lol.
I was trying to chase after him to get his plate to report it, the rexy got lucky cause I found myself in the wrong lane and having to turn away... It was literally like a scene from tokyo drift.
