Silver 34 GTR on Parramatta Road about 7PM. Asian driver with his misses, rolling next to me for a sec, waved and the GTR glanced back before I turned off to Five Dock maccas to take a leak :)
Bit of a JDM spotting today.
White 34 GTR on Railway Rd, Yennora section, driving whilst on the phone :no: gave a wave out my window
Dark blue 34 on Lvl 2 Citigate Central Hotel parking with plates X88X
Dark blue 34 4 door no spoiler on Hamilton Road with his misses at 10pm. you glanced at me and I flicked my lights at ya before turning off into 7-11 direction.
Spotted a white r33 gtst at Robertson pies today,
And also got the wave from OON-100 r32 gtr n1 on the freeway coming back, forget his sau name but his on here :) awesome car
Hey Michael, that was me mate.
Your car is stunning, easily one of the best looking 32's. My boys absolutely loved it, and your wheels look amazing when driving!!!!
Was actually going to go to Robertson as well on the way back from Jervis Bay, but decided to do the grand pacific dr instead.
That would've been Rick.
He's on here, not often though.
Didn't see any Skylines (other than Ricks) today at work.
Sadface.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
