Spotted Dino driving past the eastern valley way revenue collection point today :)
Was going to flash but then thought "what if it's some dickhead I don't know"... turns out it was some dickhead I do know so I should have :)
Hey GTR032... i think I drove past you on saturday on the F3. I didn't even see you pulled over there, then my gf was like "that was a nice skyline pulled over back there".. "I'm like WHAT?? WHERE?? you should have told me!!!"
Sorry dude, I would have pulled over for sure had I seen you.. I'm all for this "skyline family" thingy ;)
Check my sig to see if you saw me drive past... I'm pretty sure it would have been you though, how many other skylines would have been pulled over on the F3 near the Peats Ridge exit??
Was going to flash but then thought "what if it's some dickhead I don't know"... turns out it was some dickhead I do know so I should have ;)
ROFL!
yeah I thought...looks like Geoff's car???....d'oh it was!!! :wassup:
i saw another r33 on maxwell st today. im not sure if its the same one as the one i saw before.
Oh and theres this maroon r33 "series 1.5" that comes to pick up their kid from York Public school every so often. Has the stock exhaust. female driver
Sorry dude, I would have pulled over for sure had I seen you.. I'm all for this "skyline family" thingy :P
Yeh it would of been me...
Your car does look familiar, especially the silver paint & rims. Although about 6 or 7 Skylines went past that I happened to notice. Thanks for the 'gonna pull over thingy' thats cool :D
Cheers
Jono
PS..cars all good now - just cracked top plate of radiator - $40 fix.
i saw FST3** ( i forget the last 3 numbers ) on high st in penrith, was maroon.
Also while on mulgoa rd i saw a silver R33 GTR in a light shop car park just before the MegaMart or what ever its called heading towards the M4, Looked like it had IMPUL wheels.
Edit : OMFG i just saw an r33 GTR for the 2nd time in 1 day. I heard it before it past my house then the driver put the foot down and I heard the rb26 :wassup:
It makes my blood go cold and my hair stand up. thats when i knew it was a skyline. i looked out the window to see it pass, in a matter of a second the hot plate lights were gone.
saw RRR 033 today!!! She/he was turning right and i drove past...I beeped and got flashing lights in return...woohooo!!!! finally some acknowledgement from a fellow skyline driver! I was getting sick of the snobby looks and lack of response! :
Yo moanie,
that was moi!
Turned out of epping vet and noticed an unnaturally fast grey car behind out off the lights. i woulda waved and done somethin else but i had my sis, ma' and two psycho pet dogs in the car! (and u were too quick) lol
glad to get some response too. Drove past a silver 32' GTR and a black r33 25T on sat (silverwater) and didn't get a sideways glance!
T'
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
