Dude the 32 in st Clair is nice I hate the kit tho !
He drives it like a grandmas car but at the track he is pumping 300+kW at the wheel
really? it looks like ass haha the wheels and kit are a sin, impressive if it does really have that power but
Saw a black R34 GTT with black wheels at St Marys station just then I think the plates were BNQ-03Q. I was in my mums silver Camry right next to you
That was me! waiting to pick up the mrs. lol first time spotted :D
Woo! I've seen you before sometime last year on the Gt Western but that was before I got my Skyline. I remembered the black on black
Just saw Ricky(LL00LL) passing me while I was parked at Tangerine St, Fairfield East.
Flashed my high beam, saw your hazard light. You've got the High JUN stands now like me. Real niiice in all black!
Had a nice chat with Terry whilst admiring the GTR at the Charity Car show in Springwood. Was nce to meet you. Your car is stupidly nice.
You're very kind Liam. Hope you had a great day! I rolled up at about 11 thinking that all the tarmac spots would surely be taken. Our family only wished to stay for a couple of hours because Maria was on an extended test drive of a new car on the same day. Plus we bought it. So the Cameron Burke Show was only an afterthought. Great meeting with you!
  • Like 2
When will it be mine turn to own such a beautiful creation.
A little off-topic, but do you have any other pictures of this on these forums, or just in general?
I've only been privileged to see 2 or 3 photos of your car, and unfortunately they've all been of the same angle/point of view.
Thank you for your appreciation :)
I still go out to the garage at times to think how lucky I've been.
This N1 has been shown before in...
SAU > Photography > R34s
And if you require hi-res, email me on...
[email protected]
Regards
Spotted the same HR31 Coupe [YRB20T] but driving. Had a quick chat to the bloke at a set of lights.
I'm guessing he works right opposite where I see his car parked all the time, either at the smash repairers or tyre place on the other side of that T-junction.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
