oh yea thats right i remember hearing about the series 6
isnt that pic in ur avatar his old 180?
i remeber seeing that thing on the dyno at autosalon years ago
Yeh thats the same 180sx but its mine now and a lot different and of course more KW at the rear, heeh just got the thing out on the road the other day. after alot of pulling hair out i finaly have finished it .
Saw a red '33 Gtst today, "MENAGE" (i think) in Tuggerah
That's my mate Rob, he doesn't use the forums.
I followed, then drove infront of a silver SII R33 this morning on the M4 east bound from Cumberland HWY up until parramatta rd at the end of the M4. Plates were APU-66U. I was in a black Accord Euro.
Nice car dude!
i saw a nice white r33 gtr on king georges road coming from macquarie , The hid light on that car was nice and the the car look nice with a black lip i think the no. plates is pik-11e but doubt it will be right ...... next time you see me give me a wave .. i am in my r32 gtr white
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
