Spotted a black 34 parked at c o c kle bay car park last night....plates were GTS 34 or GTR 34 can't remember....something 34!  hehehe...you're lucky i was in a car driving past, or you'd have come back to find your wipers up! :rant: b
http://www.skylinesaustralia.com/photopost....php?photo=2622
spotted:
20 odds skylines at Oran Park driftland including teh winner drifter a grey r33
Yellow r32 gtr, kpgcxyz110, black 31, red 31 in Panania yesterday
About 15 Skylines, and a Bluebird race car at Gosford today
:rant:
spotted:
20 odds skylines at Oran Park driftland including teh winner drifter a ghey r33
:rant:
Fixed :)
spotted last Saturday.... white series1 R33 GTST....had some kind of aftermarket rims, and the number plate "ED"-something..
was exiting the Cumberland Hwy to some road that went to Windsor and other places, and it was around 6pm i think??
Spotted a Maron 33 GTS-t around 6pm driving onto James Ruse Dr. No Plate was GTS 10P
Thanx for honking your horn dude
Also I seen a Gun Metal grey 33 GTS-t which parks near my work at Seven Hills reg No API 11T I think, Any1 from here belong to any of these fine Motor cars?
Well I have spotted my own car!!!!!!!!!!!!!!
You all know East-Bear right? Well check out the Japanese East-Bear site! My car is on it!!! (Powerplay are official East-Bear importers and were working on my car, thus it's in the pic on the East-Bear site!).
Sweet!
Your car might be on the East-Bear site too! Check more pics here:
http://www.east-bear.co.jp/info/Australia/.../powerplay.html
saw a HOT looking yellow gtr on the back of a tilt tray truck - no plates
heading from Liverpool in the direction of Fatz place
must have been stolen : P
word is, the owner blew up the engine trying to beat a 350Z cab.
Christian
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
