Since i have this thread bookmarked (i may have to review this situation ;) )......
And also since i wasted 2 mins of my life reading this dribble that i wont get back.... :(
Ill keep in the tone of this thread..
I spotted a Chris today, as me and Chris were talking to Chris - i waved at Chris but Chris didnt wave back..
:jk: :)
:jk:    :D
LOL!!!!! What are you saying!!! that this threads all about chris??? no way!!! :(
Slim - i'm sure he has time to give you some pointers on where to start looking!! :)
Spotted a black r32 GTR tonight! on great western hwy....heading towards parra!!! :wavey: He'd had the car for 5 years! so one of the first :) Hehehe...it took me a while to pull alongside cause 'M FREE' kept blocking me! :)
Since i have this thread bookmarked (i may have to review this situation :) )......
And also since i wasted 2 mins of my life reading this dribble that i wont get back.... :D
:jk: :)
Spotted NRG-999 black gtst and LATINI black gtst covered in gtr badges... in my car park at work... waved to the driver of NRG (guy named yoshi, mate of mine) and we then preceeded to slag latini down for the badges
okay! a bit of action tonite on the roads! lovin it....!!!
firstly, R33vit: that probably wasnt me in granville :)
this all in the last 30 mins...hahaha.
spotted: yellow ER34 going down Hombebush bay drive. why didnt you play! :mad:
spotted: yellow BNR34 on parrammatta rd, "GOZYLA" fantastic :) and thanks for the fun :)
spotted: red Ferrari 360 MODENA, "MR 360", why didnt you play! ;) scared of a little RB action?!?!?! ;)
i love parrammatta rd....
lol @ franks
so what kind of "fun" did you have with the BNR34?
shyt..does anyone on these forums actually own an BNR34?
i personally have only seen like one or two of them around for like second when i drive around. So any lucky one on this forum lucky enuf to own an r34 gtr?
today i saw a silver r33 Gtst on the Gt Western hwy. Had a big fmic. I managed to get the first 3 letters of his plates, BEN *** im not to sure of the other 3.
i also saw an R32 gtst on the Gt western Hwy ( traffic lights near aldis ) it was grey. After coming back a few hours later i think i saw the same one parked on the nature sstrip on the gt western hwy
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
