Spotted this riced up red MR2 with plates RONIN at powerplay on Victora rd about 12:30 today when on lunch break, what a rice box!!! hehehe Tosh never met but you may have seen me exiting Shell accross the rd, think I saw you wondering out holding something biiiig.....
nah that's Gemballa GTR 750 EVO :P
hehe nice n confusing :)
what! has someone been watching too much initial D?
did they make that car in 1986?
I can see it now, the "hatchi-roku GTR EVO" what a car
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
