not sure on a body kit not too much to choose from here and it cost so much in frieght from the us
im thinking about paiting the bonnet the same as my avitar
There's cheap greddy front bar on ebay which will really set it off well. But I'd go with painting the bonnet too, just to make a more subtle statement.
CF vented bonnets on a stock car is like granny panties on a stripper....they function the same but just doesn't look right. no offense mate, but if you had an aftermarket bumper like in your avatar...that will really look pimpin.
https://www.sau.com.au/forums/topic/291981-new-bonnet/#findComment-4881747
I just don't see what's the point of buying the Carbon Fibre bonnet and Painting it. Could have just bought the FRP bonnet and painted it. I just think it's a pity to paint the quality work of Top Secret Bonnet (i'm guessing this is the Genuine one).
But it is just my 2 cents.
https://www.sau.com.au/forums/topic/291981-new-bonnet/#findComment-4881902
thanks for the comments guys
not sure if it genuine top secret i got it from mu secret
chris i still want to get the stereo work done but i think it
will be next year now prob around march we are going
on a cruise which leaves from brisbane so thought we could
leave the car with you for 12 days ill talk to you when it gets closer
https://www.sau.com.au/forums/topic/291981-new-bonnet/#findComment-4882016
give me a call during the week. I'll be coming back your way monday 26th. wouldn't mind a look at this.
https://www.sau.com.au/forums/topic/291981-new-bonnet/#findComment-4885399
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
