how much is a cams licence for 6/12 months any ideas? Do I need to be a member of SAU NSW to get a CAMS licence ? Cheers I'm definately interested in this especially as it's a driver training day (and it'd be my first track day) but being a wednesday I'm not 100% I'll be able to make it.
heyyo - 12 months licence for a l2s cams licence is about $90 and you do need to be a member of a club like sau nsw... but you don't need any of that crap for this day... just rock up with your drivers licence and drive!
im thinking about whether I can afford a new set of tyres before this day......im driving on square tyres after the last one and a few lock ups lols..... death wobbles ftw!
  • Replies 45
that's the thing, don't have a drivers licence ATM :happy: Can anyone confirm or deny if a cams licence will be enough for this day ??
Oran Park does not hire helmets you can buy them for about $100-150 at any motorbike shop.
You don't need a cams license, just your regular drivers license.
How many spots left Fatz? I really want to do another OP day but also hate taking days off work :)
if you cant splash 200 on a track day sell your car casue its the cause of your poverty
you fags!
poofs
fags
no really your all fags
just kidding!!!! :laugh: :laugh: :laugh: :laugh: :(:):banana:
your all still fags
I is no fag!
But the factor of the car being my reason for poverty is correct... ROFL
Trying to buy more parts for it... :)
um can you get a daily cams as a guest without sau membership? no I dont have a NORMAL DRIVERS LIC ATM
Get Petey Sweety to give you Aaron McGills number, speak with Aaron, he may let you run with only holding the actual licence, even though you're suspended... Just call and ask.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
