Hey guys, i've got a S2 R33 skyline here in Sydney thats being wrecked. It's a late series 2 with approx 97,xxx k's on the clock. Whole car is being wrecked so if youre after any small bit, chuck me a PM!
I can post pretty much everything except the seats & bootlid
Rb25det engine, good compression across all cylinders; 150-155psi. - $950 ono for the bare motor (no injectors, coils, turbo, accesories)
5sp Manual gearbox. Great condition box, shifted well and no crunching. Includes slave cyl, crossmember, shifter and tailshaft - $1350ono
I can sell this as a whole manual conversion kit if anyone is interested
Greddy Profec B Spec II boost controller - $350
Z32 AFM + plug - $200
S15 480cc injectors, will drop straight into rb25 rail - $400
Apexi PowerFC r33/rb25det, no controller - $1100
GCG Hiflow R33 turbo, good condition, no smoke. minimal/negligible shaft play - $1100
post-35556-1256802279_thumb.jpg post-35556-1256802246_thumb.jpg post-35556-1256802226_thumb.jpg
Splitfire SF-DIS-005 coilpacks to suit s1.5/S2 ECR33/rb25det and BNR34/rb26dett - $400
R33 GTR front seats, few small ciggie burns/marks on the drivers seat. Comes with rails - $750
HKS turbo timer + nissan harness - $65
GTR wing + bootlid (white) - $250 - pickup only!
2x 18x9.5" 5x114.3 +38 Starcorp wheels and tyres, big dish! - $500/pair
Also have pretty much all the stock parts for sale:
Engine bay:
3" dump & front pipe suit r33/r32 - $80
S2 Rb25det engine loom - $200
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $100
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
S2 ABS unit/pump - $100
Bm-44 ABS brake master cylinder - $75
Stock BOV + crossover pipe - $50
Exterior/suspension/driveline:
Front + Rear calipers SOLD
Rear SKYLINE garnish (white) - $50
Castor rods with aftermarket bushes - $90/pair
Front lower control arm (left side only) - $70
Front upper control arms - $50/pair
Front hubs - $80 ea
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Interior:
Floormats - $100
Drivers side window switch - $75
Drivers door motor - $90
Passenger door motor - $50
S2 door trims, full set (front+rear) good condition - $100
post-35556-1256802695_thumb.jpg post-35556-1256802677_thumb.jpg post-35556-1256802725_thumb.jpg
Instrument cluster with approx 97,000ks - $120
dash + gearstick surround - SOLD
Glovebox - $40
S2 dash pad (with passenger airbag & panel) - $250
S2 Steering wheel with airbag - $250
Centre console - $50
S2 Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
PM me if youre after anything! Cheers
https://www.sau.com.au/forums/topic/294109-wrecking-s2-r33-skyline-whole-car/
  • Replies 88
well i couldnt send a pm, guessin ur inbox is full?
im after the front inner guard liners with all bolts n clips (both left and right side) pm me price please :(
i can pick up
cheers
you have pm
wing and boot lid is mine :thumbsup:
Pm sent!
sent pm
Replied
hey mate im interested in your boost controller, but i cant pm u without 10 posts first ..
anyway man if u could pm me then that would be great ..
cheers mate,
pon
PM sent
pm sent
PM replied
im after the front inner guard liners with all bolts n clips (both left and right side) pm me price please :)
i can pick up
cheers
Sorry mate I don't have any of the guard liners
um i thought that all rb26 coil packs were the same??? and there fore not the same as s1.5/s2, instead, the same as s1
is the turbo still available !
Yep still for sale, PM me if interested
interedted in the Z32 afm
where r u located
can u email ur phone number or call me on 04036399649
PM sent!
PM sent
Pm replied
is the z32 still available am interested. if it us PM me and we can work something out.
Yep it's still for sale, Pm me if interested
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
