599s and 612s are the F cars I am most cautious of on the track as they go well in a straight line but are such terrible handlers and the traction control so intrusive they almost grind to a stop mid-corner. You need to be very carefully lined up in the 35 so that you dont run into the back of them on corner exit as that certainly would be an expensive mess. 360s are generally too slow to mix it with most of the stock GTRs we have on track days so dont really spend much time in their vicinity on the track. F355 and older are generally roadblocks that ruin everyones day. No hating, just generally find them annoying to the faster guys that want to get some track time in :(
Edited by Martin Donnon
  • Replies 280
Posted Images
599s and 612s are the F cars I am most cautious of on the track as they go well in a straight line but are such terrible handlers and the traction control so intrusive they almost grind to a stop mid-corner. You need to be very carefully lined up in the 35 so that you dont run into the back of them on corner exit as that certainly would be an expensive mess. 360s are generally too slow to mix it with most of the stock GTRs we have on track days so dont really spend much time in their vicinity on the track. F355 and older are generally roadblocks that ruin everyones day. No hating, just generally find them annoying to the faster guys that want to get some track time in :)
Haha man, R35 GTRs are roadblocks when im in my Radical :(
Would be cool if one could drive them on the road......but if I was in the market for a track car I would get a Lotus 2 eleven before a Radical.....(still love the radical but...)
http://www.diseno-art.com/encyclopedia/veh..._track_car.html
Martin, Martin, Martin.
I see you are still sore since my Ferrari lapped your Ferrari on lap 81 at Mallala the other day.
You have been most radical at attacking these fine gentlemen who like to drive their Ferraris as hard as they did when they were 17 ;)
You have been most radical at attacking these fine gentlemen who like to drive their Ferraris as hard as they did when they were 17 :laugh:
what did Vin Diesel say in the original Fast and the Furious???? inch or a mile.......
Methinks you would need some very good throttle control to use the short rev range of an LS engine in an open top club car. Traction wise, it just makes sense for them to have a buzzbox engine...
F355, F360 are POS. Italian trash IMHO. If only Ferrari can make their road cars half reliable as their F1 cars, then I will respect them more.
Like a one night stand with a hot blonde, the F355 and F360 are not the cars you want to keep long. Got friends who HAD owned them and they are more trouble than what they're worth, and believe me, they bring a new definition to the terms 'fragile', 'temperamental' and 'overpriced'.
Apart from the 'pose' factor, I can't see why anyone with half a brain and half the logic of a normal person would ever want to choose a F360 over a new GTR.
Edited by skyline_man
beacause as I said before, if you can afford one, you can afford both.... I'f you can't afford both you really can't afford to maintain either cars and your better off not wasting your money if you have to borrow on expensive cars...
Are you for real? Even if you can afford both, why would you? The GTR can do everything that the 360 can and even more. So why would you fork out 160k odd for a second hand car that will spend more time in the workshop getting repaired than it does on the road? Why would you spend 160k for a "supercar" that can't even beat a new STi or Evo?
I tell you why. It's because you're a POSER and you want the majority of people (who knows nothing about cars) to look at you and say...."ooohhhh, he's got a Ferrari"
All this talk and love of F360's makes me sick. Any of you fan boys ever had anything to do with them? Seen how fragile and poorly built they are? Seen how BLOODY SLOW they are when on a track? They're pathetic, and are simply a prosthetic extension for short balding men.
There is no contest between one and a 35, but personally, I have no aspiration to own either. The 35 is too smart by half for it's own good, they drive me nuts. GT3 for me :)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
