Another awesome DECA, thanks to everyone who organised and helped make it happen, we all appreciate it!
Poor car copped a thrashing after I told myself I wasnt going to because of the hot weather. When youre out on the track all reason seems to go out the window... you just wanna go that bit harder :P Especially in the battles, competition was red hot all day, everyone taking it to the limit and sometimes past :P Thats what its all about.
Counting down the days to the next DECA already!
Seems like i forgot to use my camera for most of the day, thanks everyone for taking photos, incredible shots! Here's one I did manage to take.
  • Replies 125
Posted Images
Thanks guys for an awesome time!!
I had heaps of fun, you were all really friendly, and it was awesome to try something new!
I even managed to get a nice tan being out there all day (on one arm anyway).
Hope to come to the next one and have a scoot around, and ill definately not miss the after party this time- sounds like you all had a great time :P
Wicked day, very hot but alot of fun
thanks to all involed in organising the day, top effort....
scariest moment is on the way back home wen the guy in the M3 screamed out "my cruise control is stuck" thanks to his throttle cable being stuck open...we fixed it, i hope he got home safe....
who got a really dark tan from the sun? i did...lol
hey thanks for the help on the way home! was scary shit hehe
was a sick day loved it :) i need to fix my dif :)
BLAKE AuST
Thanks to everyone who helped out on the day and well done to everyone for some decent times with no incidents!
Here are the results: Micolour Deca November RESULTS
Well done to Snowcone and Sidesaddle for taking out the honours.
ah damn, Moe beat me :D
i'll never hear the end of this now...
Those spins on the skidpan were very costly... LOL
just noticed i've got the same time for the miniwang on one of my runs as i got in May
Matty owned you both, his first DECA, in a stock apart from lowered, NA bmw :)
Matty owned you both, his first DECA, in a stock apart from lowered, NA bmw :thumbsup:
lol ease up ryan he probably did a spin and only lost 1 sec on my time!
I must say though some of my runs were terrible....first skidpan run i munched a few cones and missed a gear on the skidpan and long wang.
Note to self: next investment - swaybars!
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
