Isnt really performance related... so...
Originally posted by INASNT
Inark
he wont b there on the cruise!
can i borrow someone elses copy and copy it myself? whos closest to dingley? or where ever... i dont mind a driv :mad:
  • 1 month later...
  • Replies 65
Posted Images
Originally posted by RUS
Hello, My car makes the pop noise as well.  Does anyone know how to remove a steering wheel with an airbaig, without the airbag going off?  Mine was installed off center, and I would like to take it off to re-align it.
Try asking in the Technical section on the main forums, you might get better feedback
  • 4 years later...
but grim we are ready to be taught by the good doctor.
I haven't seen that much skill even on Option video's there are only a few that compare.
ex-static I told you about the day you must have forgotten.
meggala
Hmm I think you might have a smoke problem there :)
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
