Hey charles got all my parts yesterday evening but didnt have a chance to get em back in but will definatley post some pics for everyone to see, the looks awesome! cant even tell that its been wrapped!
  • Replies 477
Awesome! Glad you like it :D
That rear bar looks good man! My only issue would be being so close to the exhaust? It gets pretty fkn hot in that area when driven in anger!
So far so good, been driving in the 36degree heat :)
I think the vinyl will be fine there, as it can stand up to 200degree heat from my heat gun :cool:
But I'll keep you guys posted regarding the exhaust heat.
I'm tackling some R33 mirrors at the moment and will post up pics when finished :P
nice work you have inspired me to try wrapping some stuff on my car now i love diy :D
got any tips for other wrappers?
just bought some and looking to do the end caps of my gtr wing and mayb the wing blade down the track i see how i go!
is the heat gun necessary or would a hair dryer be sufficient?
nice work you have inspired me to try wrapping some stuff on my car now i love diy :)
Hehe thanks :)
As for tips.... Just be very patient with it because if you don't get it right the first time, you can always peel it off and try again. Also try not to stretch it too much, or else under when heated, it will shrink back to original size.
You can use heat gun or hair dryer, both does the same job. I started off using a hair dryer, but it only had 3 speeds and 3 heat settings, so I moved onto a Bosch heat with LCD display of the temp. Which I thought was much better, as I know how hot to have it for certain curves :)
lastly, remember to not over heat it, I think maximum is 250 degrees, after that, the pattern will just melt on the vinyl and become like matte black lol.
have you seen the neffy wrap vinyl? i heard its better
website is http://neffywrap.com.au or the oz distributor
http://xposed.com.au/australian-distributo...effy-wraps.html
theres pics on ozhonda for it, he actually compared the 3m vs the neffy previously as the neffy product isnt self adhesive so applying it is very easy
sample photos he has
Edited by ForevaZero
Yup, of course I've heard of it.
In fact... IMO, neffy is not better.
Yes, neffy is like 1/3 of the cost of the 3m vinyl.
BUT, neffy does not have adhesive backing, therefore, additional adhesive is required, that means, when applying, to repeel and re-use the same bit of material will become a problem. Not only that, after being applied, if you want to peel it off, that might become a problem as adhesive was used to secure it. Where as with the 3m vinyl, it's got self adhesive backing, you can peel off and re-use it as many times as you like (well pretty much), if it gets all creased, use a heat gun and boom! it returns to how it was before you even started. Or if it starts to lose the stickiness due to dust or oil, you can just wash it off with soapy water and it will stick again. Also the 3m self adhesive is easily reversible, just heat it up a little bit with a heat gun and off it peels.
Apart from that, the 3m vinyl has a gurranteed 4 years lifespan outdoor with UV protection and 12 years indoor, while the neffy does not offer UV protection and its not recommended for outdoor usage. And as much as you say you use it for interior (indoor), there will always be sun (UV) shinning in from your windows.
God damn it, when are we gonna see some r33 interior shots with this stuff?
Oh, that reminds me to upload some pics of the R33 interior that I did last week haha!
Give me a few mins :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
