I found the issue with the factory boost gauge bouncing or not working at all. If you open the sender unit, dont remove the board, just solder the three pins (at the top of pic) that run to the plug underneath and youre done. Literally a 2 minute fix.
  • Like 1
https://www.sau.com.au/forums/topic/297345-m35-factory-boost-gauge-repair/
So is that the issue then - just a bad contact on some of the solder points?
Excuse my newbie-ness, but where is this sender unit located? I have done a bit of soldering in high school but my brother-in-law is an electronics tech so I'll get him to do the actual fix up...
Is it easy to get to? or is it a case of 30 mins getting to the part, and 2 minutes to fix it...?
Steve, it is the black, roundish sensor that sits to the left of the rubber bend part of the intercooler pipe
Just unscrew from bracket, remove bottom hose and pop the tabs on each of the four sides.
That is him, in the middle.
Edited by iamhe77
Thanks mate :P
I think the ecu sensor is the one before the blow off valve you can see in the top right of the pic.
Fix it yourself, its just a dab with the iron. Easy. :P
Edited by scotty nm35
its funny, RX and ARX dont have boost gauges yet they still have the sensor lol
is it a 0-5v sensor? might be able to use that instead of installing another one for an aftermarket gauge.
digital boost readout anyone? :P
  • 2 years later...
  • 3 years later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
