I'm in need of a rattle gun for some work I'll be doing in the middle of nowhere. Not sure which combination I should use:
Rattle gun + compressor + generator
or
Battery operated rattle gun + generator
My question would be, are the battery powered rattle guns any good? I'll be using it to work on cars and farm machinery, anything from removing wheel nuts to stripping drive trains/suspension/engines and I'm not sure if the electric option will have the power to do this.
Any input would be appreciated :)
https://www.sau.com.au/forums/topic/299074-air-impact-wrench-v-cordless/
Mate of mine has a rather expensive battery pack one - it does wheel nuts up virtually as tight as a air driven one. Not a lot between the two (you can tell when you undo them).
So depends on what costs what.
I've got a Snap On cordless gun and its the best thing I've ever bought. Blows my old Snap On air powered gun out of the water!
I can use it at work for 2 days (alot of use) without having to change the battery.
Comes at a huge cost though...around $950 will get you a gun with 2 batteries and a charger. I've had this one for about 18 months and it's not showing any signs of slowing down.
It's got over 800nm of torque, the only 1/2" gun I've got that will undo a Honda balancer!
Edited by TerribleOne
Battery powered is sounding good so far. Not having to cart a compressor around is a plus and if I could get 2 days out of it I probably wouldn't need a generator.
$950 isn't too bad. I've been looking at the Dewalt for about $600, have to check out the snap on.
I'd be careful with the Dewalt one.
I've got a Hitachi 18V 3amp impact driver with the 1/2" fitting on it. It's great for your general nuts and bolts but anything really tight it struggles with and isn't really designed for it. I usually just crack the tight ones with the breaker bar, then use the impact driver afterwards. It can crack about 75% of the work I do on the car though. It did smash all the gearbox bolts on the bellhousing with ease and lasts a couple of days work so I can't really complain.
You'd be better off spending the extra money on the snap on one that is designed to do the job properly.
EDIT: Just saw the DeWalt has a bit more torque than the Hitachi one so you should be right.
Edited by Mase
The good ones are excellent. Battery life with regular use is pretty shithouse in my experience (think 1 or 2 sets of wheels then the torque starts to drop off)
but they are very flexible and convenient for occasional use. Wish I had the coin for one :P
I use an air at work and i have a DeWalt at home. Although the work one has multiple torque/speed settings, I find the DeWalt do just as good a job as the work one, and you have a bonus of being portable. Sure the batteries dont last a long time, but I bought a kit that came with 2 batteries so one is on standby all the time. If you buy the DeWalt, make sure you get the heavy duty batteries.
And 600 bucks is a great buy considering I paid 800 a few years ago.
x2
x3 its the only thing for quick engine stripdowns and that pesky balancer bolt
Replacement Wty too.
so can anyone recommend a brand other than snap on that has been worth buying? I really don't want strap on gear in the garage in case people get the wrong impression
(ie I am a fool who pays for a brand name even if there are better tools at a cheaper price)
The Dewalt is very good for around $600.Had mine for over a year and can't fault it.Around 400nm with a full battery
I recently went through the process of purchasing a cordless impact wrench and finally settled on a Makita BTW450 18 v unit.
These have comparable or better power to the "Snap On" units and the batteries are compatable with the full range of Makita cordless products. The only issue is that they are not imported by Makita Australia and are either sourced from NZ or USA.
Here is a link to one of these on ebay (I purchased mine on ebay from NZ) -
http://cgi.ebay.com.au/Makita-BTW450-18v-L...=item4a9ca0815e
What will it cost?
Impact wrench ~$300
Batteries ~$100 each
Charger ~$150
Total around $750 plus delivery for each component
These units have heaps of power and once you have the charger and batteries Makita also make some good drills, angle grinders, nibblers, etc that use the same batteries.
These do everything that the "Snap On" units do but with the new Lithium battery technology. They use a very intellegent charger with a built in fan to keep the battery cool while charging and the ability to communicate with the chip in the battery and vary the charge rate depending on what the battery needs.
What will it cost?
Impact wrench ~$300
Charger ~$150
Thats interesting. I had a look at the Makita but wasn't sure about the quality.
A group buy could be worth looking in to: http://cgi.ebay.com.au/7-MAKITA-18-VOLT-BT...#ht_1143wt_1165
Works out at around $228 for the unit (no battery or accessories).
Edited by Priestley
I paid $880 for a Snap on with two batteries three weeks ago, wish I bough it earlier. Ni-cad batteries though, need lithium ion. But they charge pretty quick.
You could probably get away with an electric gun with an inverter instead of having to lug around a generator/compressor.
Edited by aleks
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
