My engine has had some issues and now doesnt have any oil pressure. I havent removed the engine for a few years so am going to have a go at the task in the next few days in my garage.
I have an engine hoist and jack etc, but was interested in what most of you guys found easier (with limited tools), either ripping the engine alone, or taking the gearbox with it. My concern was being able to get the car high enough to get the angle needed to get the engine and box out, or potentially getting the top bellhousing bolts. Wouldnt mind taking the turbo etc out at all the same time without having to do it first.
Engine is an rb30det with 25t box in a cefiro.
Any ideas would be great.
Cheers
Edited by SirRacer
https://www.sau.com.au/forums/topic/299934-quickest-way-to-remove-engine/
Cheers
remove the gearbox first. Last person i know who tried to remove the engine with gearbox attached destroyed the radiator supports.
Im fairly certain i took my 25 out with the box still attached.
But the 31 bay is slightly different, i have a tad more room and crossmember etc sits lower, so that could be a factor.
If i had a car hoist - gearbox would have come out first >_<
took my rb26 out from the top without the gearbox attached no sweat at all
I already had the head off which made it much easier I guess
but with a few (borrow from ya mates) extensions I cant see any of the bellhousing bolts being that bad
am currently wondering though if I can actually put it back in without taking the gearbox out
I seriously doubt it so consider that too
I have a trust sump and long dump/front pipes so that adds to the problem
Been a while since I took one out to and managed by myself without to much sweat
bro arrived just after I got it out gotta love having help eh!
on the floor engine out, leaving the gearbox sitting in the car on a jack or block.. in my opinion its a risky job pulling the engine and gearbox out in one go.. things get damaged and peeps get hurt
guaranteed if you try and pull both out at the same time someone will have to hop in the engine bay to lift the gearbox up to clear the rad support.. if something lets go someone could get hurt real bad..
and the cheap cranes that most companies sell these days come of the floor easily with that amount of weight.
ps. take photo's of as much of the engine bay as you can for future reference!
leave the crossmember and gearbox attached
drop it down onto a trolley jack...
lift the front of the car up with an engine crane or block and tackle, it doesnt have to me super high...
slide the motor and box out on the trolley jack.
Edited by midnight
Pull it out as a unit.
Cefiro's have a nice long engine bay.
Get the front of the car up high and hook the chains back around cylinder 4/5 so you can angle the engine back as you lift it easily and then lift the back of the box easily too.
Edited by badhairdave
I always do my R33 engine and gearbox together. It's all about getting the perfect distance from front lie on location to the hook, and back tie on location to the hook. Get the perfect angle, you don't need to "lift" the gearbox at all.
i pull the motor and box in one unit as well, i dont lift the car at all, except to fit the engine hoist under the suspension arms (only needs to go up about 20mm max) but thats because my car is real low.
As said above, get the angle correct (pretty steep, more than 45 degrees anyway) and its simple, i have tried doing the box seperate and its a pain in the arse to get the box back onto the motor when the motor is getting put back in.
I actually made up a little trolley that sits 10 mm off the floor to sit the rear of the box on when lowering it back in so it slides back without neeeding to sit it on the floor or on a trolley jack which is just too high.
Edited by unique1
how high are you guys lifting your cars that do engine and gearbox in one go?
If you have wheel ramps then that'll do it. Or i just use my axle stands on the highest setting on the front of the chassis rails
remove the engine and gearbox out at the same time. you may need to lift the front of the car up a bit to get it out correctly depending how low the car is.
remember to drain the gearbox oil ;)
no one has mentioned an engine ballancer.
they make the job a lot easier..
i removed the engine and box from my r32 alone with a crane and balancer.
ONE OF THESE
you can use it to adjust the angle of engine and box by up to 45deg either way..
a good way to do it but take my advice... dont to it on your own,,, have atleast 1 mate with you.
Cheers guys, havent done it for a while so will get into it in the next few days. Dropped an auto box and engine out a wee while ago and just thought id let the oil ooze out. Turned into a massive headache so good to remember to do this.
Do you guys remove turbo manifolds etc, or just take the whole thing in one go? Whats the best mounting point you use also?
My stocker came out by removing the dump pipe only off the motor.
My RB25/30 I can't remember if I do it with or with out the turbo... I think I took it off because it sits less then an inch off the strut tower...
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
