Webber just re-signed with RBR for another year on his contract till the end of 2011 !!!!???? :thumbsup::):banana:
That may be the end of Marks career I think. I couldnt see another team taking him up after that.
Edited by Tektrader69
  • Replies 3.6k
Posted Images
Webber just re-signed with RBR for another year on his contract till the end of 2011 !!!!???? :):nyaanyaa::spank:
Of course it's the end of his career. Realistically he didn't have any other options. McLaren have their line-up for the next ten years I think, Ferrari appear to want to keep Massa and Alonso or replace one with a young driver. RBR are the only other decent car on the grid atm. He may have to keep reminding them he's as good a chance as Vettel to win races, but aside from that it's too late in his career to go to a new team.
I think he only had two or three years left in him in any case. He's 34 this year and most F1 drivers retire in their late 30s (unless you're a 7-time world champion who just can't let it go). F1 teams know that and few would take him now.
He`s Just MADE HIMSELF SAY $10 MILLION :nyaanyaa: for that ,So Let say THE CONTACT is worth that to anythere team so he win`s either way ,
RBR have good car so why not :yes: if was shit like they had been maybe he would look else where,
AGE well chat with Rueben`s about that & look :nyaanyaa::rofl: what he`s driving :yucky: poor bugger ,
Where was MISTER 7 :wacko: not going to well ;)
Mark`s a smart man been in the system & know`s what he`s doing ,
Good move i think,
Bet VERTOOL TO WORLD CROWN will be sweeter :nyaanyaa: for him as well (finger`s crossed for him) as it would be just reward for hard work with all the TEAM`S he has been at :thanks::wave:
Cheer`s Chuckie.
BUMP!
So this weekend they're up in Canada, with a lot of people peggin mcLaren to walk it in due to their top end speed and low drag co-efficient.
Sad to say that I don't think Webber will be in the lime light for this one, unless some F-Duct improvements have been made for him over the weekend (unlikely).
This will be an interesting GP. Lets see if McLaren can consolidate on their new found pace, or will Hamp drive into the safety car in pit lane this year?
RBR, Ferrari and Mercedes will all be trying to keep them honest and you cant help but think this race may spring a surprise with Renault.
The ol' ear nibble and reach around seems to have worked on SV, he seems pretty motivated this weekend.
I hear he was pushing the car pretty hard in P1 and P2 and topping the times in P2.
The LH and JB don't appear to be as quick as expected at this point and this track should really suit them.
its only practice- smoke and mirrors ;)
wont get a good indication until final practice, and even then fuel loads between the teams will be different. IMO mclarens will be front row after quali
I realise that practice is smoke and mirrors but someone at the track reckons SV was pushing pretty hard.
If you believe the post practice comments, LH seemed a bit disappointed in their pace in a straight line.
The McLarens should be front of the grid based on last weeks performance but the changeable weather will make it a lottery.
Man...i thought Webz had it when Hamo mesed up his lap on the softs...but he was able to make them hang in there for a well earned pole. Now will the softs fall apart, can Webz get him off the line...will Webz get a poor start from the dirty side and get chopped by Vettel?? Hell, is there a rule that the car must return to the pits after quali or is there a penalty to having to be pushed?????
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
