Good to Alfalfa and Webz shake hands in such a genuine
fashion.... Good to see Seb hang around and congratulate the others...
Piece of shit dissing Advance Australia Fair....
Waiting for the Waaaahhh in press conference.
Bet he mentions fastest lap time
  • Replies 3.6k
Posted Images
it was all about setting up vetool for the win and for some reason, they made him hold up the field, he got f**ked by the rule and webz profited. did vetel feel bad or was it a team deal? why didnt they pit webz? that was the whole race right there, maybe they thought vetel woulda got away with it? if he had, he would have been first.
No doubt Vettel would have aced the competition and I am a bit disappointed for him and his outcome, except for the fact that once again he can only blame himself for bringing about the circumstances of a disappointing result. Determined to press rivals against the wall, cutting across on another car too early when passing, lagging too far behind the SC... so many points squandered unnecessarily. For his sake he needs to learn some race craft pretty quick I reckon
He said he was caught napping, but that's no excuse really
F1 don`t need wanker`s like MS maybe 7 times champ but that should be his last time that he come`s close to putting Rubens in the WALL :banana::):banana: ,
He was a good driver but not any, once to often he has tryed to run someone off road,
How good was that. I cant blame Vettel for being a little anti-social....i mean i can understand why he was fuming.
Interesting if te team actually say, Webber with 4 wins, a few points in his pcoket...when is it too early to call for the teams focus? I hope they dont do it yet....today shows how anything can happen on a given day. If Webber can pull a few more points and head home from Japan with the lead...surely RBR will call it for the internal fight
Ask Louise or the other 18 drivers if they would take a 3rd after a drive through?
Understand it wasn't a win, and it could've been.
However these things happen.
On a side note,
Can someone explain how the Merc F-Duct gets the stall air to the wing blade?
Bit confusing for a door kicker like me.. No funnel running down the length of the rear bodywork like all the other cars.
I thought it was going to be another processional race, but was highly impressed. Webber drove a blinder in the first stint to pull out enough of a lead after being f**ked over with the pitstops. Well done son, a few more of those, and you'll be our 3rd World Champion!
As for Schumacher, he definitely needs the book thrown at him majorly. Be very interesting to read both drivers post race quotes, I can see quite a battle of words going on. That incident is clearly why Schumacher isn't the greatest F1 driver of all time, despite his stats. A man of that calibre and experience should know better.
EDIT: Also love the jump that Mark has been doing the past couple of races on the podium! He almost kicked Alonso in the head! :)
fark they love to make something out of nothing regarding the Schu/Barrichello incident. sure it was risky but nothing happened move on..
are you real :) this wanker is a WASTE OF A SEAT,f**k HIM OFF & give a YOUNG GUY a chance to drive in F1,
Not some WANT A BE back in F1,joke is on him
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
