  • Replies 3.6k
Posted Images
So.... apparently in 2013 F1's will be 1.6L Turbo 4cyl cars (with max 10,000rpm).
Guess we'll see a new wave of manufactures like Hyundi and Mitzibishi coming through!
Only cool thing is the return of ground effects as well.
it will be horrrible
But anyway, we find out how much the fine will be for team fuzz today. Doubt it will be a points deduction, just a bit of pocket change and we'll all move on
Sets a precedent at least. Hopefully it means we get some consistency in the penalty system
Please, please tell me this is a bad joke? You are kidding aren't you?
Edit; Oh no, you aren't kidding :D
I feel physically ill.... YES, I remember the turbo era, it was wonderful, but those engines (even the four bangers) were 850 to 1200hp, not a piddly 650 that this proposed reg brings :D
"Apr.26 (GMM) F1 teams are close to agreeing upon a new engine formula for the six-year period beginning in 2013.
Until then, development of the current 2.4 litre V8s will remain ‘frozen’, to be replaced thereafter by similarly powerful engines that use less fuel, emit less pollution and are affordable for the small teams.
Spain’s El Mundo Deportivo newspaper said an in-principle agreement has been reached for a four cylinder, 1.5 litre engine equipped with a twin-turbo and direct injection.
The new formula would reportedly also involve KERS.
“If F1 has to develop something helpful for real (road) driving conditions, then the best solution is for an engine that is turbocharged and GDI (gasoline direct injection,” Ferrari CEO Amedeo Felisa told Autocar magazine at the Beijing Motor Show.
“That is what we would support,” he said.
Mercedes’ Norbert Haug agrees that smaller engines are likely for reasons of consumption and emissions, but warns that high technology needs to remain a crucial focus.
“If you fly from Europe to Japan on a 747, you would use more fuel than an entire F1 season. We need to see the whole picture,” he insisted."
Paddock Talk's thoughts on this; "PaddockTalk Perspective
We continue to shake our heads over this lunacy. If Formula One isn't going to be significantly different as the pinnacle of racing, then they are acting like fools.
In our minds the super-rich billionaire owners are trying to dumb down the sport to save themselves millions and pocket that extra cash rather than put it back into research and development which benefits everyone."
Edited by Marlin
The engines in the 80s were 1500cc. They weren't exactly washing machine engines ... I know they'll be restricted but they'll get around that. Not saying we'll see 1500 bhp but I think they can get at least the same power they are now. Don't forget, even at 650 bhp that's still 1000 bhp/ton. Not bad in anyone's language ...
can't do anything more for mechanical grip- they already run slicks and tricky LSD's
going back to ground effects means the grips levels shouldn't change as much when cars are in close proximity
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
