spotted a silver 33GTR with i think white wheels with chrome dish going past the backside of the hellenic club this afternoon.
SIGSPUTNIK: thats my new boss lol, i was cruising in that thing for most of the day, and for those interested, it has 18's, aftermarket black leather int, exhaust, and a few other little goodies.
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1184046
spotted twice in one day :bananaman
thanks fordz yeah i would have been going from my gf house. the car isnt the most modded gtr around but has a nice street look
GM_GTR - yea gun metal is a very nice colour specially up close if its a nice paint job. i have had heaps of people say to me they always hated white wheels and the gunmetal colour but after seeing my car they think they actually look nice.
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1184509
i had white wheels on my gun metal r32 and thought it looked ok, i've seen far worse!
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1184936
my mate spotted (and keeps spotting) a marone 32 getting fully sideways (or fishy-ing) turning onto canberra ave near officeworks/fyshwick builders supplies (he works at the latter). he says he's seen him do it a stack of times, usually around the same time of day-ish.
thought i'd check to see if its any of you nutcases!!! hehe
d
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1185093
you mean me? if so then no it was'nt you could'nt pay me to park my car anywhere near that place.
LOL! didnt think it was you
spotted a black R33 gtst out front of tugz hyperdome, the outside looked stock but only had a quick glimpse as he was going in the opposite direction.
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1186026
Spotted two white GT-R's leaving Wagga and heading for home this arvo, - very f'ing nice, was going the other way in my purple R33, gave you a little wave - not sure if I scored was back or was snobbed!
Hope you had a good day and enjoyed Wagga - just didn't quite make it back home in time damn it!
https://www.sau.com.au/forums/topic/30059-spotted/page/120/#findComment-1186049
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
