Spotted two white GT-R's leaving Wagga and heading for home this arvo, - very f'ing nice, was going the other way in my purple R33, gave you a little wave - not sure if I scored was back or was snobbed!
Hope you had a good day and enjoyed Wagga - just didn't quite make it back home in time damn it!
G'day Stolly:yep saw you wave-just managed to wave back b4 you were gone! Nice ride,BTW. That was me(pearl white 32),Sinista(silver 32) and Tridentt150v(black R33) just leaving when you saw us...
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1186934
my mate spotted (and keeps spotting) a marone 32 getting fully sideways (or fishy-ing) turning onto canberra ave near officeworks/fyshwick builders supplies (he works at the latter). he says he's seen him do it a stack of times, usually around the same time of day-ish.
thought i'd check to see if its any of you nutcases!!! hehe
d
ummmmm it might be me Sorrry :wassup:
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1186981
they are. i agree. i dont do sideways action anymore my wheels are too big and too expensive so i toned it down a bit. anyway enough of that. also spotted the 4 door silver r34 in jerra god i lve that car
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187035
Spotted a gunmetal R32(GTR?) thismorning coming off the monaro highway out towards the airport, waved to each other
also spotted parked on Gladstone st a very nice looking 4dr R31. had frameless windows, and text on the side that indicated an RB20DET. looked very flash, i've never seen a frameless windowed R31 before.
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187113
that's one of the import models
pillarless = classy :cheers:
there's one parked on lonsdale street all the time as well
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187207
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
