Spotted a white series II r33 at autobahn belconnen...
Also spotted a black gts4 r33 with front mount intercooler on the way to civic, gave a wave, got one back!!
Also spotted a black series II r33 heading towards belconnen from civic, looked stock
Also spotted theo's R34 GTR vspec in manuka!
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1289384
Well, for a start he is my mates father, so that probably explains it.
He owns a store in phillip, not sure if he wants me to say which one either.
Hes in his early 40's so i dont think hes to interested in car forums, however i tryed to get my mate so sign up, but hes just never posted i think!!
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1289545
Lol nah dont worry about Theo, most of us know him or have met him anyway. He owns blockbuster and is vice pres of the Hellenic, we've known each other for a few years now.
I've asked him so many times to join, but its just not his thing and he's flat out most of the time anyway lol.
oh and at last check he's pushing out 290kw after the pfc install and tune by croydon.
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1289931
Well in Civic tonight.....parked infront of a stock grey R33 s1.....out the fornt of Mombasa was a White R33, low, FMIC, beasty....across the road was Cons Maroon R33 monster. As i left civic up near the canberra theatre area another white R33 with FMIC, lowered....possibly same as the first one i mentioned.
Not a bad Friday night.....
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290095
Ah cool, I work just across the street at Infinite Networks (its in the building with a reflective front window on a 45 degree angle to the street between Paragon and Kell & Rigby).
From everything I have seen, it doesnt look like a GTR (no flared guards unless im not looking close enough).
I've been spotting that same ride for months now:Amaru is right:definately no GTR. I've only ever seen it either stationary,or if it is driving,I've been on a loud mudderboike of some description(it's a work thing...),so I've never actually heard it. Even if it did have an RB26 in it,it's still a GTS/T in my books. Not that it makes it any less of a car:just like a certain full house RB26DETT in a sleeper that ISN'T a Skyline that's quietly floating around,preying on the ignorant and unsuspecting...Hey,Nik! Why are you grinning like that for...?! :burnout:
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290183
--------AT ALL 4--------------  :aroused:
So Amaru and Whytry have got nothing to worry about?! :P LOL! Remember,people:respect for your elders(a.k.a.:R32-still the one!).
If you listen carefully,you can hear Leech working up a good rebutal for the 33 crew :)
Ah,it's all jokes:Theo's ride is so,so schweeeet! :drooling:
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290185
lol its not worth it to many of these softies will back you guys up lol :P however for the people that say they would take a 32 over something like theo's 34 i say you deserve a :kick: lol
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290247
I have to say that the R34 GTR is the sexiest of all GTR's, but there is something which draws me to a 32, mabye cos its the model that started the GTR legacy... (If you forget the KPGC10GTR)!
Ah bugger it, we should all buy R31s then we could all stop arguing...
I love my car!
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290310
teeheehee. oh but so much fun i'd imagine.... if you have the gonads to try...
d
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290753
d
You'll need a set about,oh,I dunno...
...this big :D !
https://www.sau.com.au/forums/topic/30059-spotted/page/154/#findComment-1290800
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
