Spotted a Yellow R34 GT-T with an ARC FMIC,big exhaust, dark tinted windows and victorian number plates.
Yeah i spotted this car too when i was going through Belco last night.
I saw your car up at Autobarn the other day too, i parked out the front in the Stagea.
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1521689
spotted an R33 whining its way up my drive way, sounded like most R33 owners
Sorry Andrew, had to say it
Haha get fu**ed! stupid R33's though, somebody buy it!!!!!
My R33 now has bright red rear callipers, and come next week it will have bright red front ones to!
And a note to all owners out there......clean your air filters!!! I hadn't cleaned mine in the 1 and a half years that i owned it, anyway i cleaned it at andrew's yesterday and my car is soooo much better for it! it sounds so nice now and is more responsive to any touch of the accelerator and theres alot more power especially in high revs, i am simply amazed at the difference its made!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522112
Didn't see your's yesterday but see it often outside of Autobarn, good to see you're shopping at my work instead of next door lol. I was parking in the bosses spot while they were away, gotta find somewhere to park when I work now, don't wanna take it up the gutter :D
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522231
don't know it just didnt occur to me, as i mentioned to Andrew "im completely mechanically illiterate, i can make cars look good, but when it comes to making them go forwards i'm a complete retard"
That pretty much sums it up.
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522996
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
