Spotted a Yellow R34 GT-T with an ARC FMIC,big exhaust, dark tinted windows and victorian number plates.
Yeah i spotted this car too when i was going through Belco last night.
I saw your car up at Autobarn the other day too, i parked out the front in the Stagea.
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1521689
spotted an R33 whining its way up my drive way, sounded like most R33 owners
Sorry Andrew, had to say it
Haha get fu**ed! stupid R33's though, somebody buy it!!!!!
My R33 now has bright red rear callipers, and come next week it will have bright red front ones to!
And a note to all owners out there......clean your air filters!!! I hadn't cleaned mine in the 1 and a half years that i owned it, anyway i cleaned it at andrew's yesterday and my car is soooo much better for it! it sounds so nice now and is more responsive to any touch of the accelerator and theres alot more power especially in high revs, i am simply amazed at the difference its made!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522112
Didn't see your's yesterday but see it often outside of Autobarn, good to see you're shopping at my work instead of next door lol. I was parking in the bosses spot while they were away, gotta find somewhere to park when I work now, don't wanna take it up the gutter :D
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522231
don't know it just didnt occur to me, as i mentioned to Andrew "im completely mechanically illiterate, i can make cars look good, but when it comes to making them go forwards i'm a complete retard"
That pretty much sums it up.
https://www.sau.com.au/forums/topic/30059-spotted/page/194/#findComment-1522996
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
