Spotted andrews r32 last night at rj's - didnt come say hi because i didnt know which one you were:P car sounded good leaving philip on boost:D
Dayne
Yea saw ya...
thought you were just snobbin me... so i left ya.. :P
did you get your car lowered recently??
Looked pretty low.
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1602476
LOL - nah i couldnt figure out which one you were until you left! Felt like a loser comming over there and being like 'whos andrew' haha, yeah its been lowered except i'd like the front to sit a little lower but i cant get out of my driveway then.
You shoulda came and said hi:P would have been easier as you saw me driving:D
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1602849
spotted skyGTRline yesterday evening about 6 ish going through the roundabout at sulwood and athllon dr.
saw termainal in braddon yesterday arvo at about 4 ish......
also saw a hot r32 GTR going along ashlely dr yesterday morning, gave a wave, got one from the passenger.....
then later that day, saw a nice white r33 gtst in the same spot.....
then last night, i got spotted by dave in civic (i wasnt doing laps, i swear!!!), then we had a drink......it was a special moment we shared *sniff* :P
Edited by Frink
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1604953
Forgot to add, i spotted RH9 on friday night, damn that car looked sexy! Also spotted a white r33 gtst behind me on adelaide avenue just then, then got next to me... i gave a wave but didnt get one back, the guy just greased me like a tough fcuk!! :P hahaha
Dayne
Edited by LO_R33
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1604970
Spotted a white 33 GTS-T w/FMIC following me from Queanbo to Bungendore on Friday morning. thought they were going to the trackday,as we stayed together out of B'dore,but they turned off at the last Estate on the way out of town...
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1605320
oh. no that 355 with the plates "f1" is another one. gold magnesium rims? lots of carbon fibre? taylor made race buckets? the guy that owns that reputedly had it modified by ferrari in modena, italy with full ferrari engineering approval! i shudder to think how much that would've added to the final bill! he's at auto italia every year!
any 355 is worthy of a drewl, but that "f1" is a masterpeice!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/208/#findComment-1605321
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
