Spotted:one VERY serious R32 GT-R,lurking somewhere in Canberra...For sure,one SAU'er knows exactly who owns this,and a few others may have half an idea,but I've blanked out the numberplateto keep some sort of privacy about this certifiable weapon.
It's still being "run in",so tread lightly...
And,yes,it'll stop as well as it'll go,too!
Just thought you'd all like a preview!
https://www.sau.com.au/forums/topic/30059-spotted/page/212/#findComment-1618030
Oh,also spotted today:A GT3,GT2,360 Modena(red,natch...),the all new 430 in black,about a dozen Lotus Exiges,3 M3's(one drop top,two the way they SHOULD be),a Maybach(reduced from a Mil' to $899,000!!)and a Murchilago[sp?]...all at Rick Damelian's in Parra' Road,Sydney. Believe me,you'd need de millions(pun intended)to do that showroom justice...Drool worthy,even for a Nissan nut!
https://www.sau.com.au/forums/topic/30059-spotted/page/212/#findComment-1618189
Spotted a few lines down at ulladulla..
Gold 33
White 33 with black wing..
Maroon 33 with big front mount.
Also spotted Leigh on drakeford just after the BIG roundabout.. Frount mount looks good mate!
And on friday spotted Blueprint driving along hindmarsh past southers..
did you always have that dent on the drivers side door?
https://www.sau.com.au/forums/topic/30059-spotted/page/212/#findComment-1619022
i may be a newbie here, but that's a top secret tuned engine no?
regardless of whether or not, great to see some high class bred and tuned skylines hitting canberra. not to say anything of the awesome machines already here, but with the inclusion recently of the RH9 R34...great to see some top machines hitting our small city
also spotted today at ANU, dark blue series II with some paint damage, sigh - was a great colour thought
and spotted yesterday afternoon driving through the city, silver 33GTR with chrome wheels and black ACT plates, thought it was mick but couldnt see the wheels, car was beautiful all the same
Edited by GTS_DUY
https://www.sau.com.au/forums/topic/30059-spotted/page/212/#findComment-1619286
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
