shat myself today. was at lights going thru the city today, at the lights opn northbourne intersecting london cct, white 34 GTR v-spec, black plates. this dude has got one of those oversized custom black plastic plates, with an apexi logo under his rear rego, looked farken hot
got a photo of it from the car, which i might post later
Glad to see I'm not the only one who's seen this car.
Hot as!
https://www.sau.com.au/forums/topic/30059-spotted/page/221/#findComment-1656873
I saw the white 34 last friday night. May of cut him off?? Ooopppsss.
Also just spotted a burgundy/dark redish sorta coloured Stag. ON Yamba Drive. Had an elderly lady driving it (i think eek) Didnt look like the sort of SAU person, BUT!!! i may be wrong
https://www.sau.com.au/forums/topic/30059-spotted/page/221/#findComment-1657434
DJHatton
Yeh I'm the new owner that chased you through civic to braddon last night (#RB026??)... hope you enjoyed your dinner. Is anyone catching up at all this weekend? i wouldnt mind going for a cruise and meeting some of the lads from here in person
My moby is 0409027537 if anyone is out driving tonight
https://www.sau.com.au/forums/topic/30059-spotted/page/221/#findComment-1658269
spotted a black wingless r32 in civic just then - gave a wave, not sure if he waved back.
Yeh mate i think that was me, near the RSL right? I gave u a wave back but you where driving off. Its the first time shes been out with the new rims on it, my old ones where gold five spoke Work's that where hacked up.
https://www.sau.com.au/forums/topic/30059-spotted/page/221/#findComment-1658304
spotted a gunmetal R33 with kit & gold wheels, and SAU sticker across back windscreen...at the roundabout before chisholm about 5.30pm.
i have a feeling thats andrew,
gunmetalR33
has a veilside kit, came into ed's when i was work ex'ing and was running turboless with race tape holding on the AFM pipe to the inlet...worst sound ever :D
but silicon hoses are good :)
https://www.sau.com.au/forums/topic/30059-spotted/page/221/#findComment-1658591
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
