Spotted a black series II gtst near autobarn fyshwick, and a gunmetal r32 gtr (i think) outside harvey normal fyshwick, didnt see dj's car anywhere there though:P
Dayne
Hi Lo_r33,
that could've been me near harvey norman, but I was just driving past. I was shopping for a daily driver, just bought myself a pretty cool sh*tbox..lol
anyway, I spotted a yellow r33 outside carlovers.
https://www.sau.com.au/forums/topic/30059-spotted/page/238/#findComment-1723958
I saw a black R32 going past domayne between 4-4.30 Had a sweet note and a front mount.
And I saw a Silver R32 going out of Fyshwick along towards the golf course and turned at the lights before the Driveing Range Had a huge NISMO sticker across the windscreen. If you where here you also had your stereo on quite loud and I was bopping along with your tunes :P
https://www.sau.com.au/forums/topic/30059-spotted/page/238/#findComment-1724176
Saw Leech's ride parked securely in Manuka last night(at least I think it was Leech's...),and an R34 GT 4 door,dark blue,parked near Deep Dish restaurant(also in Manuka...)
The R34 dark blue 4dr is my mums. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/238/#findComment-1726668
spotted one of you boys with a red R31 Silhouette....whoevers got the blue numberplates :P
i think you saw me too...coming out of hyderdome about 5pm
Oh that was you
heh if I'd known I would have waved :blink:
https://www.sau.com.au/forums/topic/30059-spotted/page/238/#findComment-1727025
oh yea i keep forgetting to post i keep spotting this blonde in a really really bright 300zx in woden area. I never get a decent look at her but blonde and an ok car (with the exception of the paint) DMAMNNNN
Thats the pink one right?
yes... very HOT!
https://www.sau.com.au/forums/topic/30059-spotted/page/238/#findComment-1727033
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
