Spotted John's R31 going under the bridge leaving Queanbo' on Monday arv'. Looks VERY different to the last time I saw it,J! Spotted Andrew the NEW owner of Andrew's Veilside 33 at trivia last night;good to finally meet you!
I agree - was good to finally meet some of the guys off here. :P
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1770985
Hey white R33 S2 with nice bodykit and plates "SKY33T" you passed a stock-ish silver R33 S2 on your right, heading under commonwealth bridge towards Fyshwick.. that was me! Driving slowish cos I was on my way out to Ed's for a much needed broken part! (throttle sensor)
Anyway, G'day.
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1771313
now now kids! play nice.
spotted black r33 gtst. tv's in headrests. sounded much more tough than any sub 2.6l engine has any right to (teehee) and looked pretty noice. manuka around 9pm ish near tryst.
d
hey man, sure it was a gtst? sounds alot like mine and i was there at that time... and mine has the gtst on the rear boot at the moment:) i saw your beast in manuka too... the reason for the badge (yeah i know its rice) is i needed a new boot, and its yet to get painted, even though the paint is the exact same:)
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1772309
spotted ib6ub9 going through civic this arvo, about 3ish.....
also seen a silver R33 s2 with an sau sticker on the back window and a poorly kept R33 GTR (was a dissapointing example...) both at inline this moring....
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1772939
Spotted Jayce trying to steal bits from certain GTRs on Sunday arvo. Little bugger was trying it on in front of the entire AutoSalon 2! I told him off...
Bugger! Sprung! It's so hard to make off with 430KW's of RB goodness without Paul & Stace' noticing...LOL!
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1773976
Gunmetal R32 GTR with white TE37s parked up about 0930, not saying where in case it goes there a lot.
White R34 GTR heading along Commonwealth Ave
haha. that'd be mick, the guy who a) imported my car and B) has imported many many many other cars under the now defunct 15 year rule. good bloke. and i pleaded with him for his wheels, but no such luck :rolleyes:
i'd love to know which establishment he was parked at! :)
d
https://www.sau.com.au/forums/topic/30059-spotted/page/249/#findComment-1775977
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
