spotted a silver 33 gtst last night going past the old jerra shops at about 10-10.30. had a cf bonnet which looked very similar to the one kronic has and was wingless, but also had some big yellow decal down the side, cant remember what it said but <_< by what i saw the driver was short, or his seat was just heeeeaaaaps far back.
anywho, ive never seen it before
That'd be one of the ESP Racing cars,the other being "Shafty's" big-hitter Supra.The owner isn't the tallest fella I know,but is a nice guy that's put some work into that 33-it used to be a standard Marone model,but it looks HEEEEEEAAAAPS better now,dontcha agree?
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1905832
Shafty's car is pretty nice...
My EX bosses old car..
It was just a clean looking Supra before he got into it.. we did the aircon on it a lil while ago.. DAMN! very nice under the bonnet.
Spotted Andrew in his lil thingy beast.... outside Maccas today.. i turned into maccas in front of you. dont think you noticed.
Also last weekend spotted MIVEC heading round the round about at Erindale, Was in a mates car goin round as you entered.. DUDE! normally we wait for cars to go past before we jump on the R'Bout.
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1906405
Hehe, I know all those roundabouts (Erindale & Isabella Drives) well enough to know exactly when I can and can't enter the circles.
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1907846
Spotted Snoozies car down Charny shops Saturday - no sign of Shaun. Mayhaps you were in the bottlo :D
Your CF looks and fits great.
where the f**k were you, (better yet what are you doing in bogans ville) spot on I was in the bottolo
Edited by race_snooze
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1907939
Yea.. you may know the road.. but its the drivers you have to watch for..
Thoes guys are unpredictable. :P
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1909064
Hmmm - cant remember wot I was doing in Charny.... I wasn't picken up crack hoes, wasnt buyin cronic, not collecting money, didn't bash anyone, wasnt stealin cars, although yours was tempting....
Oh thats right a driveby.......Run for cover Mutha f***ker ...Bahaha
Nah - I was visiting my Mum
https://www.sau.com.au/forums/topic/30059-spotted/page/268/#findComment-1909407
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
