You weren't at the School Reunion at the Crowne Plaza were you?
haha can't do anything in Canberra without ppl finding out Adam! yeah, he was ;)
spotted wingless silver R33...waves exchanged and then followed him thru Kambah/Mawson, also a wingless silver R34 in Wiluna St Fyshwick about 5.30pm.
https://www.sau.com.au/forums/topic/30059-spotted/page/274/#findComment-1946622
Haha yes I was.  How did you know?  Canberra so small you know every event that's going on?
I was at that venue, but not at the party. My mate was having his 25th there as well, we were over in one corner. i couldn't figure out what was going on with people wearing name tags everywhere, but then it clicked.
Also we chatted to some people who said there was a reunion.
https://www.sau.com.au/forums/topic/30059-spotted/page/274/#findComment-1947191
That was me!
I spotted a black ceffie on Coulter Drive yesterday and got a wave.  I get more waves in Canberra than Sydney and I'm only there about 5-6 times a year.
HAHAH... it's dark green mate (thinks, must have a black perl in the paint) :( and I'm from NSW... thought I'd pay respect to a fellow 4 door man :lol:
Cheers,
Grant
https://www.sau.com.au/forums/topic/30059-spotted/page/274/#findComment-1948691
spotted a bayside blue R32 with a T-wing going down the parkway this arvo, and also passed a black R32 going the same way, at the same place at about 8 (near the intersection of lady denman + parkway)
https://www.sau.com.au/forums/topic/30059-spotted/page/274/#findComment-1949063
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
