spotted a white r32 gtr in fyshwick near bob jaaaaaane t mart. red seat covers. very nice! the white volks could do with a wash.
i also saw what looked a lot like a Humvee H1 in woden, around lunch time. Bright red. It looked like a Hummer, but I really don't think it was a real one. It just didn't seem big enough. A body conversion maybe?
https://www.sau.com.au/forums/topic/30059-spotted/page/297/#findComment-2103042
thats a H1 but the smaller version (yes there are versions) holdens looking to bring the smaller H3 to AUS to sell :)
why? for all DA p1mp D4dd1ies! Y0!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/297/#findComment-2104609
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
