yeh, ill be making an appearance at the museum this friday as posted on the museum thread.. poker nite was at jerra club, they have it every monday nite.. thursday nites at roos club in qbn..
Tuesday nites at the Tigers club qbyn.
Canberra cant conform ATM.
https://www.sau.com.au/forums/topic/30059-spotted/page/318/#findComment-2390750
That would have been me going to pick up the girlfriend :D sorry i didnt see you. I was sitting behind a evo 8 most of the way
Spotted a black R33 going along the parkway towards woden about 4:45. I was ging the other way... Didn't get time to give a wave because I only just noticed it as it was going by.
https://www.sau.com.au/forums/topic/30059-spotted/page/318/#findComment-2395740
spotted a nice sounding dark blue R31 going over Hindmarsh tonight at about midnight.
Do you know if it had chrome rims or white rims??? There "was" a stolen blue r31 with white rims(dirty when i saw it last) with no center caps, r31skylineclub sticker on the rear drivers window and a handsized paint chip on the front quater. The cops called me today and told me they found it. I did see the thieves but a 2nd statement would be heaps better, if you saw anyone???
Anyways, feel free to pm me and i'll give you the case number to give a statement, if you want.
And if it had chrome 19inch rims then don't worry... his car ain't stolen yet...
https://www.sau.com.au/forums/topic/30059-spotted/page/318/#findComment-2399129
oh.. sorry to hear, was it your car that was stolen?
I couldn't see much sorry!!... it was really dark and we were going up the hill on Hindmarsh where there's no streetlights or anything...I just came up behind him and then went into the middle lane and passed him.
I didn't even see the rims properly :P but thinking back I reckon there might have been a flash of bling when I went past so maybe it was the other guy.. I think he might have been alone in the car too - the stolen one would have had at least 2 guys in it??
Where did the cops find it?
https://www.sau.com.au/forums/topic/30059-spotted/page/318/#findComment-2400405
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
