Spotted myself on drakeford drive on the side of the road friday night with a rear end 10" shorter than normal. And to all those wankas out there who yell out of their doof doof mobiles or taxis - F U!!!!!!!! I know i was in a crash, and i don't need everyone to point out the obvious, no need to yell it like a bogan out ur window as you drive at 5km/h then hoon away. My girlfriend was so impressed by them, thought they were so cool.....NOT! THey nearly caused so many crashes slowing down.
Saw a skyline zoom past. think it was like 830ish maybe.
Edited by 33Sedan
https://www.sau.com.au/forums/topic/30059-spotted/page/342/#findComment-2585748
spotted a burgandy 33 in curtin near the shops at about 11:30ish then a black r32 gts-t on state circle at about 11:45 or 12ish looked nice and then a white 34 gt-t in fyswick at like 12:45
hehe that black R32 was me :wave:
Spotted a yellow R34 Gtt at chapman shops all the time.
spotted a white R32 gtr at tuggeranong office park on friday mmm dirty but sexual :)
https://www.sau.com.au/forums/topic/30059-spotted/page/342/#findComment-2586187
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
