spotted a red Ferrari 355....just sitting there next to me while i was filling up at BP... almost put way too much petrol in cos i was just staring at it :) soooo nice. an older guy came and drove away, sounded awesome.
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2770167
Was it the purple one? If it was i followed after that car for about 20 mins about a week ago :)
i am fairly sure it was black, but there can't be too many of those c5s around?
edit: ah, i see, there's a place i queanbeyan that complies them.
Edited by sigsputnik
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2771799
Saw sl33ky at the long stay car park in the city on friday morning (perhaps starting work?) with the mrs?
Uh....Sl33ky IS the Mrs.
I thought her name being Emily might have given away the fact that Emily is a girl.
Unless I've totally misread your post and gotten confused?
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2771996
it aint a line (except for the tail lights) but earlier in woden i spotted this corvette c5 convertible. i was driving so i couldn't get pix, but it was VERY nice:
plates said "C5". i think nsw but could have been act i guess.
saw that bad boy driving down hindmarsh the other day too. very nice!
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2772024
spotted a white 33 in qbn on fri arv. i think the plates were SL33KY, not 100% sure tho...
spotted another white 33 looking at chrissy lights in McKellar last night and followed yet another white 33 through kambah early this arv
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2772441
i think i spotted bluprint at som lights last night..sticker on the rear window?? i was high beamin ya lol
Wouldn't have been me, I don't have a sticker on the rear window... you probably saw James who has a car almost identical to mine
Leshy - I probably was looking at some tail, Woden was mighty impressive in that department today :P
And Pete - we saw you too :(
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2772750
It was with the girlfriends family sorry :P
On the way home from the go karts ran into jayce on the push bike (not literally) and we said merry christmas :(
Also spotted Leigh at the go karts in Fyshwick. Where was my invite Leigh!! (we went to Hume instead).
https://www.sau.com.au/forums/topic/30059-spotted/page/364/#findComment-2772907
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
