Had good day today.
Black and a white 32 in Erindale.. doin' something to the rear left wheel.
I pulled over and asked if they were ok, but I couldn't make out what he was saying at times. haha.. so I drove off.
And a maroon 32 heading out of Lanyon.. I gave a small fingerwave from inside coz I was lazy.
https://www.sau.com.au/forums/topic/30059-spotted/page/380/#findComment-2897547
Spotted Datman (r33 owner) at GasTune today around 1pm. Great to meet you and have a quick chat, sorry if I was a bit out of it, having a bit of an average day at work, and trying to get a stalling problem fixed as well on the car. So I was in a bit of a hurry.
https://www.sau.com.au/forums/topic/30059-spotted/page/380/#findComment-2902174
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
