My bad i thought it was leshy, when people spell my name right i will spell yours hehe :P
Name's Leshy, get it right... crikey.
That would have been my missus going to work at the hospital, as she's been driving my Stagea around for the past 2 months while Toyota do a really efficient and cost-effective repair job on her Corolla. I'm now cruising around in a crappy red VL commodore, so don't bother trying to spot me :)
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2962920
Thats me :D
Nice to meet you..on the forums,anyway! Sounds nice,your thing!
Delayed spotted:me hopping out of the tired old Liberty to help a stopped R32 GT-R(in beautiful Bayside Blue)on Dairy Flat Road last Saturday arv'. Whilst he's not on the forums(yet),the young owner is a nice guy,so if you see this car,make sure you give him a wave!
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2967537
Is that the one with the plates RB026 or similar ???
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2968124
Can't remember the plates,but do remember that it was at F & F Imports for sale for a little while. Basically a stocker with nice rims and a choice colour applied...
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2968140
Now I know why the plates were familiar;Veilside just jogged my memory! Dave's 32 (RB026) was 'Calsonic Blue',the one I stopped for was "Bayside Blue"- two different model colours and eras,but excellent nonetheless!
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2968194
Also i finished work at like 12:30 driving back to my hotel room and what do i see bucket loads of imports on the main drag here in Christchurch i mean heaps. Side of the roads littered with them. So i pull over to watch and see what sort of cars are around (may as well nothing else to do) and some kiwi comes up and starts chatting to me for like 20 minutes he was a champ he was there with a guy in a nice clean RX7 and R34 GT-T. Anyways at the 20 minute mark a cop siren sounds and i wish i had my camera everyone jumps in there cars and flys off up to road GOLD...
Anyways spotted mainly
WRX
Legacy Wagons
RX7
Evo's
R32 GTS-T (although most of these were pretty crappy condition big dint's,scratches, rust etc)
R32 GTR
R33 GTS-T
R34 GT-T
https://www.sau.com.au/forums/topic/30059-spotted/page/391/#findComment-2969198
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
