Ahahah, it was a sale attempt.
Nah a chick rang me up and wanted a squiz so i met her in braddon (im in woden, shes in gungahlin) and went for a drive and talked it up etc.
Was good :wub:
I walked past you, I should have jumped in and pretended to have seen the car and that I really wanted it to make them buy it because they thought it would sell quick.... but i'm not that fast at reacting.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3044899
Spotted what i think was Andrews 32 in Dickson, same colour and same bodykit, around 1pm
Spotted another purple 32 behind turning off drakeford around 11am
spotted my car in full blow D-spec mode aswell:
cant really see in pic but the entire car has a layer of dust and dirt on it, its all nice and pretty now though :wub:
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3044993
No worries man, she hasnt got the coin yet anyways.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3045037
pfft that car aint dirty :stupid: try cleaning your car after a drift day j/k, nah it isn't a bad effort.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3045058
the 2 r32's at intergra motor sport dont look half bad ither (1 grey 1 white) they have been sitting there for about a week now
lol who is getting mods done?
the gray ones mine, getting the turbo high flowed and a bigger fule pump put in
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3045189
parked or moving?
im parked in Ainsle durin day, if it was parked it was me... if it had no front bar.. it was me.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3045253
nice clean car viper.
how much is the work setting you back if you dont mind me asking?
To much actually, all up its costing me about 3 grand. I know that’s expensive. But the main reason I decided to go a head with it is because the GCG high flows have a very good reputation. And GCG have assured me that I will see a top end of around 220rwkw with only a small loss of 200-300rpm max in lag. To be honest that’s pretty darn good. I’ve seen aftermarket HKS and Greedy stuff do worse. Once it’s all together CEF11E will be tuning my ECU. And I have just recently purchased an Apexi AVC-R, which is still to go in. but once Its all done ill post the dyno graphs up.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3046382
Spotted a white Ceffie with white rims,a BRIDE drivers' seat and two or three tickets on it's windscreen parked facing the wrong way on one of the streets next to PJ O'Reilly's last night...Anyone know it?
Also spotted on Tuesday night: a marone 1000HPatw R32 GT-R in a secret locale in Queanbo'...and yes,I've seen it on the dyno:the figures are the real deal.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3046417
parked or moving?
was parked and i only saw the back :X
it was near a construction site, not sure if it was in Ainslie but it was near Dickson college
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3046530
that things been there since thursday man, i went past ot thursday arvo in same spot :P
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3047141
saw a maroon R33 top floor of DJs carpark at Woden... had rims, high rear spoiler and black shopping list.
also a red s14 who i thought might have been low200?? on corinna street woden a little while ago... but i dont really know what your car looks like and it was dark..
also spotted a taxi driver indicate and change lanes straight into a massive tradies van (how you could NOT see it I have no idea :) ) so I stopped and offered to be a witness for the tradie... good thing too, the taxi driver was trying to get out of it :)
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3048150
also spotted a taxi driver indicate and change lanes straight into a massive tradies van (how you could NOT see it I have no idea :thumbsup: ) so I stopped and offered to be a witness for the tradie... good thing too, the taxi driver was trying to get out of it :)
Taxi Drivers are getting out of control in this city. :)
Which is wierd, because if you use canberra cabs you don't actually get to where you need to on-time.
https://www.sau.com.au/forums/topic/30059-spotted/page/401/#findComment-3048679
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
